tips on refitting the side strip back on
The English speaking Kadett C fans can use this forum to chat about all kind of Kadett C topics.
Moderator: rellie kel
alymac
C geïnteresseerd
Bericht door alymac »
going to be refitting the side bump strip on my caravan, the doors and front wings will have no mounting studs but have bought some off these
i have looked but cant find new trim clips large type can you buy these?
also looking out for new strips for the front wings. how hard are they to find, found the rears and the doors new.
patrick de boer
Re: tips on refitting the side strip back on
the are olso avalibel on ebay
whit the firm cald reproparts or somting like that
patrick de boer
i cal the local opel dealer
i need drop of 1 for a example the wil try to find mor of them
patrick de boer
hello i found
som clips in a very hard reeds place
i think between 20 and 30
i wil drop of a example ate the dealer
alymac
C geïnteresseerd
thanks for that!
patrick de boer
is there a spending limit for you? I wil give you the recit whit the parts
patrick de boer
and how many do you need
alymac
C geïnteresseerd
hi was looking at replacing all with new! will go and count them now,
patrick de boer
okay you need 8 on the back side panel of a saloon i dont now whit a estate
patrick de boer
and my rearlight are on there way
i wil here wen you reseve them
alymac
C geïnteresseerd
8 on the side panel for caravan
6 on the door
6 on the wing
20 per side!!
patrick de boer
okay and is there a spending limit ? Because 40 a bit can be a lot
alymac
C geïnteresseerd
any idea how much is for one?
patrick de boer
not jet
patrick de boer
the dealer cant found any (jet the will send a mail to al dealers on monday)
but there is a nother solution but that wil not fit the parts you bought
this works a little bit difrent
you dril a 6 mm hol
put clamp on it
place a fork in it
then a center pin
and then you cant mount your side strip back on
there around a 0.50 euro cents a peace this includs strip en mounting fork wit pin
Gebruikers op dit forum: Geen geregistreerde gebruikers en 15 gasten
