tips on refitting the side strip back on
Moderator: rellie kel
going to be refitting the side bump strip on my caravan, the doors and front wings will have no mounting studs but have bought some off these
i have looked but cant find new trim clips large type can you buy these?
also looking out for new strips for the front wings. how hard are they to find, found the rears and the doors new.
Re: tips on refitting the side strip back on
the are olso avalibel on ebay
whit the firm cald reproparts or somting like that
i cal the local opel dealer
i need drop of 1 for a example the wil try to find mor of them
hello i found
som clips in a very hard reeds place
i think between 20 and 30
i wil drop of a example ate the dealer
is there a spending limit for you? I wil give you the recit whit the parts
and how many do you need
hi was looking at replacing all with new! will go and count them now,
okay you need 8 on the back side panel of a saloon i dont now whit a estate
and my rearlight are on there way
i wil here wen you reseve them
8 on the side panel for caravan
6 on the door
6 on the wing
20 per side!!
6 on the door
6 on the wing
20 per side!!
okay and is there a spending limit ? Because 40 a bit can be a lot
the dealer cant found any (jet the will send a mail to al dealers on monday)
but there is a nother solution but that wil not fit the parts you bought
this works a little bit difrent
you dril a 6 mm hol
put clamp on it
place a fork in it
then a center pin
and then you cant mount your side strip back on
there around a 0.50 euro cents a peace this includs strip en mounting fork wit pin
you dril a 6 mm hol
put clamp on it
place a fork in it
then a center pin
Gebruikers op dit forum: Geen geregistreerde gebruikers en 10 gasten
