rostyles banded
Moderator: rellie kel
rostyles banded
i am having these banded and not to sure about what size to go?
i would like to have them as wide as possible 8? or best to go for 7.5? dont want to do any mod to the body,
Re: rostyles banded
This is 8j with mods to the body ... if you don't want to do the mods and want to go low ... this is to big !!
Mine was lowered 85mm at the front & 60mm at the back
Greetings,
Erik
Re: rostyles banded
i want to run some biggish tyres 185/60 so may just have to settle with 7.5?
Re: rostyles banded
7.5 J may be too wide also. This probably depends on the offset (ET-value) of the rims.alymac schreef:i want to run some biggish tyres 185/60 so may just have to settle with 7.5?
7J "ATS Classics" with ET 20 will fit without changes to the bodywork and 185/60 will fit nicely on the 7J rim.
Re: rostyles banded
if you want to test fit
you can place a spacer
than thake the fiknis of the spacer to the rim
sorry for the crapy english
mss een vertaler
mss een vertaler
Re: rostyles banded
like erik said, 8j is too wide, 7.5j at the back and 7j at the front should fit without any mods to the body.
it depends also of the stongnes of your suspension.
if you got weak shockabsorbers, then the tyre's can hit your wheelarches.
7.5j with 185-60-13 tyres should fit nice at the back
and 7j with the same size tyres at the front.
Re: rostyles banded
looks like 8j will be +5et 7.5j will be +12et
these are fitted to my coupe 8x13 with et -6 on rear and -1et on the front
Re: rostyles banded
just had a set of wheels banded went for 8" in the end, just need to have them blasted clean and painted
not the best picture
Re: rostyles banded
Nice coupe.. more ratstyle! I like it!!1
