The English speaking Kadett C fans can use this forum to chat about all kind of Kadett C topics.
Moderator: rellie kel
alymac
C geïnteresseerd
Posts: 55 Joined: Sat Mar 13, 2010 3:51 pm
Contact:
Post
by alymac » Mon Aug 09, 2010 6:23 pm
i am having these banded and not to sure about what size to go?
i would like to have them as wide as possible 8? or best to go for 7.5? dont want to do any mod to the body,
Automatic-freak
Posts: 1803 Joined: Mon May 15, 2006 10:56 pm
Contact:
Post
by Automatic-freak » Mon Aug 09, 2010 7:47 pm
This is 8j with mods to the body ... if you don't want to do the mods and want to go low ... this is to big !!
Mine was lowered 85mm at the front & 60mm at the back
Greetings,
Erik
alymac
C geïnteresseerd
Contact:
Post
by alymac » Mon Aug 09, 2010 8:39 pm
i want to run some biggish tyres 185/60 so may just have to settle with 7.5?
corsa-erik
Posts: 469 Joined: Mon Jan 22, 2007 8:32 am
Post
by corsa-erik » Tue Aug 10, 2010 4:38 pm
alymac wrote: i want to run some biggish tyres 185/60 so may just have to settle with 7.5?
7.5 J may be too wide also. This probably depends on the offset (ET-value) of the rims.
7J "ATS Classics" with ET 20 will fit without changes to the bodywork and 185/60 will fit nicely on the 7J rim.
patrick de boer
Posts: 1406 Joined: Thu Jan 18, 2007 8:13 pm
Post
by patrick de boer » Tue Aug 10, 2010 4:59 pm
if you want to test fit
you can place a spacer
than thake the fiknis of the spacer to the rim
sorry for the crapy english
mss een vertaler
kadett coupe
Posts: 1545 Joined: Sun May 21, 2006 10:23 am
Post
by kadett coupe » Tue Aug 10, 2010 5:16 pm
like erik said, 8j is too wide, 7.5j at the back and 7j at the front should fit without any mods to the body.
it depends also of the stongnes of your suspension.
if you got weak shockabsorbers, then the tyre's can hit your wheelarches.
7.5j with 185-60-13 tyres should fit nice at the back
and 7j with the same size tyres at the front.
alymac
C geïnteresseerd
Contact:
Post
by alymac » Tue Aug 10, 2010 10:01 pm
looks like 8j will be +5et 7.5j will be +12et
these are fitted to my coupe 8x13 with et -6 on rear and -1et on the front
alymac
C geïnteresseerd
Contact:
Post
by alymac » Sat Aug 28, 2010 7:15 pm
just had a set of wheels banded went for 8" in the end, just need to have them blasted clean and painted
not the best picture
Bear79
Posts: 1420 Joined: Mon May 12, 2008 9:06 am
Contact:
Post
by Bear79 » Fri Dec 24, 2010 9:14 am
Nice coupe.. more ratstyle! I like it!!1
Bear79
