En nog een helemooie. Met info altijd leuk om te plaatsen.
Engine: Isuzu G180 1.8-litre SOHC, bored to 2l. Port matched and flowed head, 3-angle cut valves, heavy duty valve springs, 30-70 Ivan Tigh camshaft, double row timing chain, forged flat-top pistons, moly rings, balanced conrods, crankshaft and flywheel, RPM heavy duty clutch, Jap. electronic distributor plus igniter, electronic coil, 8mm leads, twin 40m IDF webers, 4-2-1 Lukey extractors, 2 1/4" exhaust with 3 inch tip, custom front and rear wiring harnesses.
Body: Mitsubishi Icebell Blue metallic paint (body) with badges removed, mid grey/silver metallic paint (under body), chromed diff cover plate, engine block & cylinder head painted body colour (high temp paint), chromed components, braided hoses, GTS Monaro side mirrors, re-chromed front and rear bumpers, tinted windows.
Interior: Mazda MX-6 front seats - recovered in dark/light grey velour with patterned insert, , Gemini rear seat - reshaped with the same trim as the front seats, re-skinned custom designed dashboard, door trims covered in light grey velour and patterned insert, dark grey plush pile carpet, modified centre console, Autometer oil pressure and volts gauges, remote boot release in glove box (from VK Calais), central locking. Custom boot - MDF panels covered in light grey velour (houses both amps, CD stacker and DSP unit).
Suspension and brakes: Gemini 5-speed manual, balanced tail shaft, Gemini ZZ/R (Japanese) 4.11 LSD with ZZ/R discs and single piston sliding callipers, Bendix sports brake pads front and rear (rear pads same as RX7 series 1 pads), Whiteline 24mm front sway bar, Whiteline 13mm rear sway bar, K-Mac 35mm lowered front springs, K-Mac 50mm lowered rear springs, Monroe GT Gas front shocks, K-Mac Gas shortened rear shocks, nothalene suspension and driveline rubbers. Most under-body parts painted high temperature dark blue.
Wheels and tyres: Vault savannahs 17-7 with 205/40 nankang rubber.
Stereo: Pioneer head unit, Pioneer DSP unit, Pioneer 12 stack CD, V12 amp, Alpine component speakers, Alpine 6x9 speakers, Lanzar amp, Lanzar 10-inch sub.
gr gerry
Gemini Sedan
Gemini Sedan
