78 Chevy Chevette RARE BIG BLOCK 427
http://www.ebay.com/itm/331330068884
YES IT IS A CHEVETTE ON STEROIDS NOT A CORVETTE
WELL HERE WE GO CAR STARTED OUT AS A ALL ORIGINAL TWO OWNER CAR THAT WAS ALWAYS GARAGED AND KEPT IN EXCELLENT CONDITION. WHICH MADE IT EASY TO COMPLETELY RESTORE USING NOS PARTS AND TRIM AND BRIGHT METAL
INTERIOR RESTORED TO ORIGINAL PLAID DESIGN WITH NEW EVERYTHING RUGS HEADLINER PAINT ETC, PAINT AND BODY RESTORATION IS TWO YEARS OLD PAINT SHINES LIKE GLASS BODY LASER STRAIGHT NO RIPPLES OR WAVES . SIKINS BASE COAT CLEAR COAT URETHANE PAINT.
BIG BLOCK 427 COMPLETELY REBUILT L88 ALUMINUM GM HEADS SOLID LIFT CAMSHAFT GM HIGH PERFORMANCE ALUMINUM INTAKE WITH HOLLY 780 CARB. FOUR CORE CHEVELLE RADIATOR WITH TWIN COOLING FANS. ALL FITS UNDER HOOD WITH NOTHING SHOWING .
FABRICATION TO CROSSMEMBER, FIREWALL ,AND TRANS TUNNEL. FRONT SUSPENSION REBUILT WITH HEAVY DUTY SPRINGS HAS DISC BRAKES WITH RACK AND PINION STEERING , TURBO 400 TRANSMISSION WITH 3000 STALL CONVERTER , NARROWED 12 BOLT REAR WITH POSITRACTION WITH 390 GEARS. HEAVY DUTY REAR SPRINGS AND CUSTOM LADDER BARS.
ALL PARTS ARE NEW IN THE BUILD AND FABRICATION WAS DONE BY A PROFESSIONAL CHASSIS SHOP .YOU CAN DRIVE ANYWHERE, RUNS COOL DRIVES STRAIGHT AND MELTS TIRES. TAIL PIPE IN REAR IS FAKE THE EXAUST IS FULL LENGTH AND ROUND MUFFLERS TUCKED UNDER CAR POINTING TO THE DRIVESHAFT.
THIS IS NOT A RACE CARE I BUILT IT TO BE DIFFERENT FOR CRUISE NIGHTS AND CAR SHOWS SOUNDS AWSOME
FOR INFORMATION CALL RON AT 609 585 8244
78 Chevy Chevette RARE BIG BLOCK 427 (V8 - 7 ltr...!)
